Online: beaglebasher, HD17
What's Missing???
  • WhatTaxi
    WhatTaxi
    The sporty
    what do i win ?
    i can only see 2 gaskets missing  for both sides of the backing plate spacer  as long as 2 main allen bolts are  the right lenght  , you use the original   chrome cover, clean out the element  & re oil if 2nd hand, wash from inside out only
    there just a stock air cleaner gasket for the c.v. carb models all the same 1987 -2004 you will need 2,   i can't remember if the stock bolt's  are long enough you can check when you do the job ,
  • Sparra
    Sparra
    Hey there Z man...Thats gonna look great on your bike and make it purr real sweet......I'll pm you my address...
    Cheers...Sparra
  • TheBoss
    TheBoss
    Make sure that particular model does not require 2 "BREATHER BOLTS" at the mount. Without it, you'll loose oil pressure!
