Online: Adam76
Belt tension guage
  • Peter
    Peter
    So if I wanted to buy 1.belt tension gauge  2.Derby cover and Inspection cover gaskets (not a whole gasket kit) . 3. Tranny drain plug o-ring.  4.Oil filter.  where can I order them all from the same supplier ??
  • Peter
    Peter
    Just trying to save postage Thruster,has anyone heard of reliantgasket ? I just found them on E-bay supposed to be top quality gaskets ? They seem well priced,any suggestions welcome ?
  • Peter
    Peter
    Yeah thanks thruster but looking for an ebay shop to buy from,reliant is selling 6 inspection cover gaskets for about $12 and 2 derby cover gaskets for about the same,pretty cheap but I just gotta find out what part number the inspection cover gasket is for an 06 softail ?? I thought they were all the same until I looked at his shop. Scotty are you there ??
  • Peter
    Peter
    Thanks for the part number Thruster,as far as adjusting the belt goes I haven't had two mechanics agree on how tight it should be so I thought the gauge was playing it safe. I found the jpcycles site but I haven't worked out how to order on it yet ?? Yeah Red with the tensioner alone it is probably worth going to the dealer.
