How Do I adjust the rear shocks on a 2010 Fatboy
  • pedrod59
    pedrod59
      Hi,
    Just wondering, has there been a thread on adjusting the rear shockies on a Fatboy?
    I have a 2010 FLSTF and and want to know how I adjust the rear shocks?
    It is OK while solo, but does bounce a little while 2 up only on the rougher roads. They are not too bad, but maybe I could improve them a bit.     Maybe if I can set them a little firmer that would help.
    Does anyone know, what the factory sets the spring rate at from new?
    MY Fatboy is only new, so they are not due for replacement yet
  • AJ56
    AJ56
    By memory the factory sets the shock at a single rider,pretty soft when 2 up. If you haven't got the tool you will need to get one to adjust the shock preload pressure.. Note white spot of paint before you adjust so that you get even pressure on the springs in the shock assy. Turn the shocks an equal number of turns, if they are all the way out try just 1 complete turn and if is not enough go further. It's a bit of suck it and see.
  • pedrod59
    pedrod59
    Cheers mate,
    I was having a look at the manual as suggested by robo61. The manual is a bit vague, but I appreciate your advice especially about marking it with white paint.
    I have bought the spanner last time I was at the Harley shop, so I will give it a go next chance I get.
    Thanks again
  • AJ56
    AJ56
    hilly your a bastard
  • pedrod59
    pedrod59
    LOL,    .............I think he is a funny bugger,
    Now why would I go from a  Fatboy to a Dyna. My idea is to buy better. Getting a Dyna would be going backwards wouldn't it?
  • pedrod59
    pedrod59
    Just stirring actually a dyna was one of my choices when I went shopping, but after looking, thinking, dreaming the Fatboy won the choice. I thought of buying one of each, but the missus put her foot down  and said only one and I gotta do what she says.
    When I win the lotto, I'll have my way.....................................
  • HDrider999
    HDrider999
     Get a Legend Air Suspension. They last a lifetime and adjust with a handlebar control for riding 1 up or 2 up, rough roads.... whatever. I love mine. They have reviews and videos on their website.
