open face helmet
  • bathory
    bathory
    Hi there, could anyone please advise me on which open face helmet to buy that doesnt sit on my skull like a pumpkin! All the open faced ones ive ever owned always sit high up and the only way i could get them to sit right was to pull the guts out of them. Obviously i was  a lot youger then when the consideration for my own safety didnt exist. Would appreciate some assistance with this as are picking up my new sportster next month.....
    thanks
  • Rick1310
    Rick1310
    I find this is a good one I also have the fullface version & the both fit my melon well.
    http://www.mcas.com.au/_product.php?section=1&prodid=8972
  • Bushchook
    Bushchook
    I found the Nexx brand to fit well and sit a bit lower than the norm. I've got a typical german shaped head with corners and found it hard to get one to fit comfortably at all.
    Like Hilly points out, the M2R are quite good as well.
  • Zorrohd
    Zorrohd
    the bushranger is not available anymore although its still shown on the website
    the cannonball is the one you want or if you want something smaller try the desperado of neither are ADR approved.
    we stock both
    www.zorros.net.au
    Most ADR approved helmets are much of a  muchness in terms of the size. yes you can buy a small adr helmet and meltdown the foam there are some people refitting the inside of the helmets which would seem to be a better bet as with any ABR (poly) helmet Plastic helmets and thinners dont mix that well in terms of strength of the helmet.
  • BURTO
    BURTO
     RXT Challenger (size XS) and a hot spoon!
    Burto.
