Online: bikenut57, John.R
Video of my sporty with Screamin Eagle Street Performance Mufflers
  • kingchops
    kingchops
    Here is the comparison video of my sport with the Screamin Eagle Street Performance mufflers:
  • Taffymarsden
    Taffymarsden
    Hi Kingchops. I followed your advice and had a listen to this. Fantastic! What difference is there between standard SE slip ons and Street Performance please? Yours look to be slash-out. Are these better sounding then the slash-downs or is the difference just appearance? Any engine tuning required with these? Sorry for all the questions; I'm new to Harley-Land but really appreciate your help and this forum. Gil
  • kingchops
    kingchops
    Taffy,
    The older SE slip-ons were louder but you can't get them any more, I believe the SESP are the only ones you can buy now.
    I only had the slash out and have never heard the slash down so not sure about that.  I'd say there wouldn't be a lot of difference.
    If you fit pipes only you don't need any tuning mods, but if you fit both pipes and high-flow air filter then you need to do stage one mod to your tuning.
    I do recall a decent difference when I fitted just the slip-ons and then it was better again after adding a high flow air cleaner and stage 1 tuning.
  • Taffymarsden
    Taffymarsden
    Thanks Kingchops. Gil
  • costum666
    costum666
    i put onscreamneagles racing pipes to my cust1200 -slip on sounds great
    cheers 666
  • MADOGA
    MADOGA
    Sounds good , I like my Rush 2.5inch slipons better though.
  • Taffymarsden
    Taffymarsden
    Kingchops, thanks for all your advice, which I followed. Instal finished a week ago (details on signature) and I can't believe the difference. Spins out like crazy and the sound is perfect! What a machine this is now. Thanks again.
    535.jpg picture by taffymarsden
  • kingchops
    kingchops
    Nice job Taffy, those pipes look great.
  • Ken777
    Ken777
    I have SE street Performance muflers on my 2011 Sport Custom
  • Urban Guerilla
    Urban Guerilla
    Sweet bike Taffy, and cheers for the vid Kingchops!
  • Ramakill
    Ramakill
     Thanks KC, I've been thinking that way myself especially with the bulk of the warranty still to go, will keep HD happy.  Haven't seen too many reviews of the SESPT yet, it being so new, but I'm assuming they would have a reasonable map for my SESP slipons +  SE A/C stage 1 combo.
    Anyone else care to comment here???
