Online: beaglebasher, HD17, Hilly
Electrical accessories
  • Wingy
    Wingy
    I want to put some Oxford heated grips on and dont want to go straight off the battery.....draws 4 amps max ............couple of questions......2007 dyna superglide.
    1.......can I pick up power from behind the key..
    2......key is in headstem how do you remove it..
    3......is there a place in the fuse panel for accessories..
    I know I will get shit for being a soft cock... but a couple of mates have them and they recon they are shit hot......cheers wingnut.
  • Wingy
    Wingy
    Thanks Steamer thats a good idea...I was also going to run a relay as well... just to be safe...........with the seat off there is lots of blank connections as I dont know what they are for I will go with your suggestion....cheers wingnut.
