Online: Stuart
Chrome Handlebar Clamp Bolts for 2010 Fatboy
  • pedrod59
    pedrod59
    Has anyone bought some Chrome Handlebar Clamp Bolts for a 2010 Fatboy?
    I want to change the zinc coated clamp bolts to some chrome ones, but I can't seem to find any. Harley Davidson don't seem to have any listed for the 2010 Fatboy, but have listed a kit to suit up 2006.
    Does anyone know if the 2006 kit will fit the 2010 model.
    Maybe aftermarket I could get some, but I am not sure where? and what size to get.
    At the moment I don't want any risers and want to stay with the standard bars.
    Has anyone changed their zinc coated bolts to a chrome set?
    Peter
  • Inkman
    Inkman
    Mate just replace them with stainless steel and give em a buff.
    Thats all I ended up doing and they look just as good as chrome.
  • pedrod59
    pedrod59
    Thanks,
    Do you happen to know what size and thread they are?
    Also what type of head are on yours?
    Any photos?
  • Rocky2010
    Rocky2010
    You can buy chrome caps to go over those ugly allen head bolts and they will look great when you do that also they aren't too expensive.
