cam cover
  • jonatyre
    jonatyre
     Hi I have an Ultima 127" with a flaw in the chrome on the cam cover. My question is what is the easiest way to remove and replace. I have limited mechanical knowledge and wanted to know if i can do or is it a bike mech job.
    Cheers Jonesy
  • jonatyre
    jonatyre
    Hi I got the engine in a kit bike I purchased, still havent replaced the cam cover but will soon. I ran/rode the bike yesteday for the first time and all seems to be ok. A few minor oil leaks which should be easy to fix, heaps of power I see a few have dynoed at 127 rear wheel hp.
