Online: WideglidingNZ
rear shock setting
  • Hoodaman
    Hoodaman
    I ride mainly two up....The ol RKC is a little spongy on the rear end but i havnt changed it since i got it......How should ideally i set the rerar shocks for two up riding???
    Thanx yoall....Hoody
  • Hoodaman
    Hoodaman
    Thanx Hogbag........Now I think Ill get that pump tomorrow and take it up to what u say.....Thanx again problem solved...
  • twincam88b
    twincam88b
    Thanks for that Hogbag, I must get me a pump as well.
  • Harleyglide
    Harleyglide
    alternatively you can get a good quality pump from any push bike shop for about 20 bucks cheaper, thats what I use.
  • twincam88b
    twincam88b
    Got a pump today and have just read the recommended pressures in the manwell, will be interesting to see what pressures they have set the bike up from new.
  • twincam88b
    twincam88b
    Well guess what, the pressure was zero.......I wonder how long that has been. I have jacked it up to 20psi as I do mostly 2 up riding. I will check it after the next ride. The pump is a quality bit of gear, should have got it straight away.
  • Hoodaman
    Hoodaman
    Well Ive just gone and bought me one of those shock pumps today and what a peice of quality it is.....Still way overpriced but im really happy at how easy it is to use.....Found I been runnin 2 up with only 15psi in em......took it up to bout 23 and WOW.....what a better ride that is....wish i had asked this one sooner....
