Online: DIVOT
flat battery / ignition
  • flattracker
    flattracker
    Alright...to say I'm mechanically challenged is an understatement, so I need some help. I have an 09 XR1200. I went to start it and the battery was flat. I charged the battery, bought a trickle charger to maintain it over winter, and put it back together. When i turn the key to ACC, i get instrument and head light. When I switch to ignition everything goes off. Any ideas?
  • smeemn
    smeemn
    Check the voltage,ignition on voltage should be above 12.50v. if not replace the battery
  • als1200
    als1200
    Bugger,  was the battery fully charged?  12.8v.  the battery could still be the problem, just putting a load on it ( head light ) may have just highlighted the fault.
    make sure all your earths are really good and clean.
  • Hound_Dog
    Hound_Dog
    Sounds like your battery is fucked mate
  • flattracker
    flattracker
    Thanks guys,
    I think the battery is rooted. I did pull the maxi fuse out first as the alarm goes off as soon as you disconnect the battery if you don't.
    Appreciate the feedback.
  • flattracker
    flattracker
    Thanks guys,
    I had the battery tested today and she's buggered. Got a price of $180 for a new one!
    Thanks for the help
