Online: DIVOT
What next with my Fat Bob?
  • Roddo
    Roddo
    Bought a new Fat Bob in Feb, very happy. Put Rush mufflers on and sounds ok. Any tips on what I can to do to enhance the performance a bit?  Haven't got a lot of cash as I've just forked out a hunk on the new ride. Any tips appreciated.
  • Gilbo
    Gilbo
    Rush are pretty good for slip ons, what size baffles? I put 2inch in mine and it sounds mean. Go for an air intake of some sort and maybe a tuner to give it more fuel as they run lean from factory. Then there is pegs and grips, sissy bars, seats etc etc. Have a look through the Dyna section of the forum and you'll find plenty of Fat Bob pics, it just depends on what you want to spend and what style your after ;)
  • xcited
    xcited
    Hey Roddo,
    Mate as for cheap Performance upgrades you brought the wrong brand of bike! Nothing cheap when playing with Harley's!
    But your next step is a hiflo air cleaner and tuner. There are heaps of different brands out there just need to find the one you like.
  • Glaz
    Glaz
    G/day
    I would sit on the pipes till you can raise some more founds.Then go a performance A/C and a race tuner.
    Im running a TTS and SE heavy breather with Rush pipes goes good.
  • smeemn
    smeemn
    Run it in about 10000 ks should loosen it up abit.should go good then
  • Roddo
    Roddo
    Hey Brett,
    I'm not talkin cheap, but I spent 30K cash in Feb so I just want to do things gradually as I get to know the bike. A bit more low down grunt is what I reckon I need after 2,500 clicks. Thanks for the tips though mate.
  • Roddo
    Roddo
    Thanks Smeemn, good advice, appreciate it.
  • Roddo
    Roddo
    Thanks HogBagger
