Online: Stuart
Vance & Hines Power duals - can't tune on FLHX
  • Micky J
    Micky J
    Got a set of power duals and high out put slip ons trough my local harley dealer in Perth, bought as a new package with bike.
    Only problem is they can not tune the bike with these power dual headers on. Have swapped different slip ons and still can't tune in. Seems there is not enough bottom end back pressure, ok at 2500 rpm and above. So they have put the original headers back on with my high output slip ons and presto it runs beautiful.
    Has anybody here had trouble with the power dual header pipes?
    2011  Street Glide 103     211 cams   SE pro tuner
    Mick
  • kaboom
    kaboom
    i have got a set of big shot duels on my 07 roadking &im quite happy with them
  • beagle
    beagle
    Be interested to hear how it goes after a while. Have been considering adding air and cams to my 103 SG. Only has pipes and PC V at present, but runs very well.
  • aussiesport
    aussiesport
    try changing to a thundermax or tts tune !!!
  • jacks
    jacks
    The Thundermax should do it
  • jacks
    jacks
  • kaboom
    kaboom
    i was wondering what was the difference between power duals v h &big shot doals v h
  • Nanard77
    Nanard77
    I had the same problem with the Power Dual for my Road King 2010
    After analysis it was the O2 sensors were not well placed or not sufficiently in contact with exhaust gases
    Therefore impossible to make tunes
    The difference are the sensors after 2009, for example, 2010 and 2011 are different and smaller, not the same diameter. Their operation is
    completely different
    I asked the question at V&H and no satisfactory answer
    Maybe you are luckier than me but we must try and keep me informed
    bernard
  • Nanard77
    Nanard77
    that's right, when I asked at V&H said it to me never had this problem
    I'm curious that someone ask this question
    What can be done, do you have an idea
    Can they desoldering, or can they be cutting
  • malibu_lxi
    malibu_lxi
    im putting on dresser duals not the power duals only because i like the look of the dressers.
  • Micky J
    Micky J
    Vance & Hines basically told me the same, they have not had any issues with this set up using their 'Fuel pack'
  • GRUVY HD
    GRUVY HD
    Dont lke V&H, put on new big shot true duels and lost 10HP at the rear wheel. told the steelers to take em off and put the standard headers back on with 4inch SE slash cuts. all good now.
  • Nanard77
    Nanard77
    I just made a countersunk 20 mm in diameter and 6 mm deep and "Bingo" when I pulled up, everything works fine without "waiting"
    vtune my first and everything is ok
  • aussiesport
    aussiesport
    you would think with all the r n d they do it should never happen , esp on something so simple its all jigs and cnc so go figure !
