Damaged rear hub
Damaged rear hub
Shauno67
Hoping someone can point me in the right direction. I had a bearing collapse in the rear wheel and it has damaged the hub (bearing seat)it is no longer perfectly round. Is there an engineering shop that may be able to resleeve or machine for a larger bearing. Any help would be appreciated. Thanks
smeemn
What sort or wheel is it ie.spoke or mag.If its spoke then just buy a new hub.If its mag then a wheel specialist would do .don't know where you live so can't suggest any where.
Shauno67
Thanks. It's a standard chrome 09 fatboy rim. I'm in Brisbane.
