2012 IRON
  • davide
    davide
    Hello All.
    Just thought I would let you guys know that I have just ordered a 2012 Black Denim Iron, the bad news is it will be here in October.
    Anyway here is what is going on my Iron as I have alredy purchased these item.
    - LED fuel gauge
    - Flipped mirrors
    - Side number plate bracket
    - SE 1200 Stage 2 kit with roller rockers, tappets and performance bee/hive valve springs
    - V&H 2 into 1 performance pipe
    - Progressive fork springs and 440 rear shocks at 12"
    - Joker Machine air cleaner
    - JM foor pegs
    - JM side speedo assembly
    - JM bar clamp
    - Zodiac drag bars
    - Rizome grips
    - JM fork caps
    - SE shift light
    I'm going for the black/alloy look, all the JM parts are natural alloy.
    Can't wait for the bike, well thats the plan hope you guys like it.
  • SJ
    SJ
    Hey Davide.
    Putting the 1200 kit in straight away or after a bit?
    Also where do you purchase flipped mirrors?
    Enjoy tinkering mate.
  • mintpaul
    mintpaul
    Hey David,
    It will be a beast when your done, post plenty of pic's.
  • davide
    davide
    Hello SJ.
    The mirrors are the one's that come with the bike, I will just flip them and see what they are like.
    Regarding the 1200 kit, I will just put on my exhaust and ride it for a bit, this will also help me burn in the ceremic coating
    on the V&H pipe. I think this is the best idea, also if there are any warrenty issues with the bike it's best ride it stock to see if
    anything pops up.
  • davide
    davide
    Cordie.
    I like the 48 but not the fat tyre.
    Nightster is good too but I cant' get it in denim black along with the motor and the Iron wheels.
    I can do this 1200 Stage 2 kit put in and tuned on the Iron and save $500 in the process, If I were to buy the Nightster and pay extra to make it look like the Iron it would cost much more.
  • mintpaul
    mintpaul
    Hey Davide,
    Which 2into1 are you getting?
    Comp or the Roland Sands?
  • davide
    davide
    Mintpaul
    I have the V&H competition series pipe, the Roland Sands pipe is called the tracker pipe and is also made by V&H.
  • Rocky2010
    Rocky2010
    RSD 2 into 1 Tracker is a great looking pipe, have one on my bike but the ceramic coating is crap, already had mine replaced and the new one is doing the same thing.
  • Taffymarsden
    Taffymarsden
     That is a hell of a ride. I'd have a rave about how good the Iron is but everyone is sick of hearing about it! (Good luck with the side plate - more people seem to be getting away with this). Th eflipped mirrors look great but it's not for show - in the normal position all you can see is your arms. Flipped is like panoramic.
  • SJ
    SJ
    I know flipped mirrors mate.... got em on my iron underneath and they do show a lot more as Taffy says. Stock position is 80 per cent shoulder for me. I just forgot the key board doesnt show sarc (purchased being the word)  ; }
