Online: DIVOT
bike lifter / jack / trolley
  • brad65
    brad65
     I was wondering if anyone knows a suppliers in Perth that sells a wheeled bike lifter, i need it for a fat boy low, I dont have a lot of room in the shed and it would be a whole lot easier to manoeuvre the bike to a safe spot.
  • blueystar
    blueystar
    plenty places to buy them in perth for starters try repco or super cheap
    the new hd dealer over the road from the grey hound track has them to
  • SuperGlide
    SuperGlide
    mate they are not so great in the sense that you need to strap down to be properly safe/stable, also, with the weight of your Fattie on there you really need a schmick flat almost polished floor to be able to make it roll around very well with them little castor wheels
  • brad65
    brad65
     Good advice might give it a miss, i am going to the new HD shop today i will check theirs out today, i think they are around $400, i will see how they look
  • Frank7214
    Frank7214
    Try Radum, plenty to chose from.
  • Fangio
    Fangio
    brought one from repco a few years back lasted two months then packed it in...junk
  • SoftailSteve
    SoftailSteve
    http://www.ibbikelifts.biz/ if you go into his page you can ask him if it is suitable for your bike.I found him very honest and helpful..I've got a heritage and it lifts it very easy.
  • Rocky2010
    Rocky2010
    I have 2 IB Lifts, one for the Sportster and one for the Fatboy, they are excellent lifts very easy to use and when your bike is on the lift it is accessable both sides of the bike also you can move the lift 360 degrees due being on steel wheel castors.
    Most other lifts are just to bulky and don't allow you to work on both sides of your bike.
    Check the website out and see for yourself the ease of use http://www.ibbikelifts.com/lifts.php
  • russ4570
    russ4570
    REPCO $277 saw one on Sunday, looks and feels like all the rest of the chi-wan (Chinese, Taiwan) imports.
    If the IB is local, BUY IT. I will when I get the spare$.
  • SoftailSteve
    SoftailSteve
     ib lift is a quality bike lift. And it's worth the extra money. Great service from these people, if I ever needed another bike lift it would definitely be an ib lift.
  • Rocky2010
    Rocky2010
    Suppose they need something to get the girls to buy these lifts, they just don't have respect for Men
  • Rick1310
    Rick1310
    I have a IB lift for my streety & its light & easy to use worth every penny. Also aussie made.
