Online: Soapbox2627
Exhaust Heat-Ouch!
  • Annie888
    Annie888
    Can anyone tell me if there is a heat shield for the FLHTCU ??
    Because the stiff leg angles straught down, I am getting cooked on the back of my thigh and it flamin' well hurts.
  • blueystar
    blueystar
    yes harley have a heat shield for the flhtcu i gave some a way on the forum
  • beagle
    beagle
    Part number H58002-09 mid frame air deflector. Suits very late models FLH frames. Just put them on my SG. 103. regards, beagle
  • Annie888
    Annie888
    Thanks guys, will check 'em out :)
  • Rick1310
    Rick1310
    They look good as well bluey thanks once again.
