Sporty 'head breather'
  • Mr.Mow
    Mr.Mow
    So I've found an aircleaner I really like (Still Kickin' from Eternal Combustion), I asked if it would fit an EFI 2011 sporty and got this response..
    "Yeah, the CV pattern also fits all the newer EFI setups. You just need to add an aftermarket brace / head vent setup like with any air cleaner."
    Ok, dumb noobie question.. who, what or where.. ?? I'm not really sure what I need to find here, is there a kit someone can link me to?
    Right Here
    http://www.vpw.com.au/productgroup.asp?bike=1&CatID=850&SubCatID=850&priorCatID=850&PrdGrpID=711
    I will even give you a discount
  • Mr.Mow
    Mr.Mow
    Ah, thanks Walka, hopefully be in touch with you guys sooninsh for one of those patriot fuellers too
