Online: obisteve
High Voltage Error Code Night Rod
  • Gloved1
    Gloved1
    Hi All,
    I have a mate with an 07 Night Rod, he dont work with Computers much so i am asking this question on his behalf. Occasionally the check engine light comes on. He took it to a mechanic, who said he had an error code (he thinks it was # P0262?), and was told it related to High voltage somehow. The code was reset but appearede again at a later date. This time he fitted a new battery and it has been sometime , but it has just returned. He only rides occasionally, and Harley Mechanic not in our town.
    If anyone can provide some guidance it would be appreciated. I was thinking maybe Voltage Reg but only guessing. Feedback appreciated
  • AJ56
    AJ56
    PO262 is Front Injector High. I think it is the voltage that the injector is putting out which means it is running rich.
    DTC FAULT CONDITION MODULE
    B0563 Battery Voltage High TSM/TSSM
    B1004 Fuel Level Sending Unit Low Instruments
    B1005 Fuel Level Sending Unit High/Open Instruments
    B1006 Accessory Line Overvoltage Instruments
    B1007 Ignition Line Overvoltage Instruments
    B1008 Reset Switch Closed Instruments
    B1131 Alarm Output Low TSM/TSSM
    B1132 Alarm Output High TSM/TSSM
    B1134 Starter Output High TSM/TSSM
    B1135 Accelerometer Fault TSM/TSSM
    B1151 Sidecar BAS Low TSM/TSSM
    B1152 Sidecar BAS High TSM/TSSM
    B1153 Sidecar BAS Out of Range TSM/TSSM
    P0106 MAP Sensor Rate of Range Error Carb
    P0107 Map Sensor Failed Open/Low Carb
    P0107 Map Sensor Open/Low EFI
    P0108 Map Sensor Failed High Carb
    P0108 Map Sensor High EFI
    P0112 IAT Sensor Voltage Low EFI
    P0113 IAT Sensor Voltage Open/High EFI
    P0117 ET Sensor Voltage Low EFI
    P0118 ET Sensor Voltage Open/High EFI
    P0122 TP Sensor Open/Low EFI
    P0123 TP Sensor High EFI
    P0261 Front Injector Open/Low EFI
    P0262 Front Injector High EFI
    P0263 Rear Injector Open/Low EFI
    P0264 Rear Injector High EFI
    P0373 CKP Sensor Intermittent Carb
    P0373 CKP Sensor Intermittent EFI
    P0374 CKP Sensor Not Detected Carb
    P0374 CKP Sensor Synch Error EFI
    P0501 VSS Low Carb
    P0501 VSS Low EFI
    P0502 VSS High/Open Carb
    P0502 VSS High/Open EFI
    P0505 Loss of Idle Sped Control E
  • AJ56
    AJ56
    The IM (instrument module) is capable of displaying DTC's (diagnostic trouble codes).
    Speedometer Self Diagnostics: The speedometer is capable of displaying and clearing
    speedometer, tachometer, TSM/TSSM and ICM/ECM Diagnostic Trouble Codes (DTC).
    1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
    2- Push odometer reset button in & hold.
    3- Turn ignition switch to Ignition and release odometer reset button. Background lighting
    sould illuminate, speedometer needle should sweep its full range
    and indicator lamps (battery, security, low fuel, check engine and cruise) should
    illuminate. The word “diag” should then appear.
    4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with
    the first P flashing.
    5 - Each letter represents an area of the diagnostics module. The module that is flashing
    is the one you are going to check. To move from one letter (module)
    to the next, you push the odometer reset button one time. (from P to S to SP to t and back
    to P, etc.)
    P = ECM/ICM (Electronic Control Module (EFI) / (Ignition Control Module, 'Carbureted')
    S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
    SP = speedometer
    T = tachometer
    6 - To get the DTC within an area of diagnostics, push and hold the odometer reset button
    in for 5 seconds and release. If there are any DTC’s the code will be
    displayed or the word “none” will appear if there are no DTC’s. Push the odometer reset
    button again to view additional codes if they exist.
    7 - Record the codes.
    8 - If DTC’s are not to be cleared, Press and release the odometer reset button. Part
    number of module will be displayed.
    NOTE: To determine if a code is current or historic, clear the displayed code by pushing in
    and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up.
    Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it
    down then recheck the DTC’s again by repeating steps 1 to 9.
    If the code is current it will reappear.
    9 – Press and release the odometer reset button to continue to the next module.
    10 – Turn Ignition switch to OFF.
  • Gloved1
    Gloved1
    http://www.gwizit.com/harley/codes.php
    after reading this site i reckon he must have error code P0563 and not P0262.. Tks
  • AJ56
    AJ56
    Possibly Voltage Regulator. Put a Volt Meter on the bike and see what voltage he gets. It should say in the manual what voltage to expect at certain revs. Also check all connections and especially the ground wire fro the Regulator. Does you mate have a manual? If not I will have a look at home tonight as I think I may have that one and post the pages to use to check Volt Reg
  • Gloved1
    Gloved1
    Thanks for the feedback guy's. I have also donbe some surfing and when time allows will do the IM display diagnostic check. From what I can gather the DTC is being held but not current. Pretty sure he has amanual, but thanks for the offer of assistance with the pages. Will post once we find cause and share findings.
    Tks
