Slip Streamer Windshields
  • robcig
    robcig
    I'm not going to pay $500 plus for a Nostalgic Shield from the stealers!!! Has anyone had any experience with these shields. They recommend the classic Police Shield  15" high for my Deluxe? Scroll down the bottom of the page, any thoughts comments?
    http://www.slipstreamer.com/Product/Cruisers/cruisers.html
    BTW, including delivery...$140
  • robcig
    robcig
    I have Steamer. About $460 from M&M, and similar $$ from Luke. I only want to use it in the cooler months, so I don't want to spend too much!
  • paulsails01
    paulsails01
    Hi Robcig,
    I have not seen the shield that you are referring too, it would certainly look good on a Delux.
    Have you considered the range from Memphis Shades? I went through the same scenario you are going through, finally settled for the Memphis "El Paso" with detachable mounting kit all up cost was under $400 landed in Oz and some 18 months ago when the AU$ was not as good as it is right now.
    I recommend the Memphis range, quality is good and I have no "crazy" streaks through out the shield as of yet, it will come as UV does eventually break down all plastics.
    The detachable fittings are easy installed, good quality and the whole unit is very stable when under way.
    Hope this may help, cheers Paul.
  • robcig
    robcig
    Anyhow, got it last week, put in on, played around with the angles etc etc....Is now for sale on E Bay.
  • Rocky2010
    Rocky2010
    Did you think about a WindVest screen, they are made well also there not too big and bulky and looks great when fitted.
     http://www.windvest.com/
