Online: obisteve
removing softail deluxe front hub cover???
  • mattyb
    mattyb
    hey all,
    ive got a softail deluxe and im looking at removing the front wheel chrome hub cover thing,
    is there much involved? also does anybody have any pic's of someone thats done this before?
    thanks
    matt.
  • Burnzi
    Burnzi
    It will be easy to do and it will look as good without the hubcap as my bike will look good with the hubcap...... when you send it to me.......thanks.
  • mattyb
    mattyb
    lol, what do you use as a stand to get the front wheel off the ground? im guessing you need to pull the front axle out to remove the hub cover?
  • WozzA
    WozzA
    there is a circlip that holds it onto the spacer...  remove the clip & you can take the hubcover off the spacer...
    YES you got to lift it to get the axle out.. & dont forget to put the spacer back on...
  • mattyb
    mattyb
    cool thanks WozzA , whats the best way to lift the bike? do you need a bike lift? or a couple of mates and like a milk crate? lol
  • WozzA
    WozzA
     I normaly lay under the bike & crack a erection... & up she goes..  FFS  get a bike lift...
  • Burnzi
    Burnzi
    Block of wood, push bike onto side stand and push wood under, easier with 2 people
  • mattyb
    mattyb
    yeah i might see if any mates have a stand, if not anyone in melbourne wanna give me a hand
  • SoftailSteve
    SoftailSteve
     get a bike lift makes it easy
  • mattyb
    mattyb
    yeah looking into a bike lift atm.
    im in eltham Milo, how about you?
