hi guy's
Iam in the process of fitting a 19' rim (cast alloy ) from a low rider to my 94 roadking and i need some help finding someone who can make up some spacers up for the rim or does anyone know of a kit you can buy . the difference between the the hub sizes is 65mm . its a twin disc front end . any ideas would be great .
Picko from Southern Custo Choppers at Strathpine/Brendale be able to do em for you in house. 32057282
hi, not a very good idea to fit-up as the wheel bearings will be inboard to the forks on a 3/4" axle , putting a skinny wheel into a wide fork as it's just not the disc that don't mate up, asp with a ( heavy bike like a roadking ), plus it's too hard to get into the wheel bearings to grease on servicing, no wideglide hub aval the overall $ would not be too great
just mick @ A1, he will tell you the truth as a good idea or not
