brembo brakes
  • beetlebug
    beetlebug
    Can anyone tell me where I can get Brembo (genuine)  front left brake caliper to fit my 2006 dyna street bob. I need better brakes because I have just had 103 stage 4 fitted
  • andij
    andij
    i think vrods can fit ,harlet dealers or usa .you should go twin brembos ,i got brembo on my 07 dyna definite improvement but the twin disc is better and safer
  • andij
    andij
    has the 06 got 49mm legs forgot to ask
  • beetlebug
    beetlebug
    the inner tubes are 49mm, I would prefer to only have single brembo rotor and caliper.
  • beetlebug
    beetlebug
    has any one had anything to do with QTMI in usa, apparently they have brembo brake calipers etc.
  • beetlebug
    beetlebug
    Thanks for that advice, what is oem is that the standard rotor? I would replace rotor with the brembo one if it is possible Cheers Alan
  • beetlebug
    beetlebug
    what model or part no of brembo caliper did you use on your dyna, and did you replace rotors as well?
