my nighster front spokes are getting pretty bad with rust after only 3 years i want to replace them is it hard to do yourself or should i get someone to do them if so does any one know anyone on the sunshine coast who will do them thanks
Ok, I'm not an expert on respoking, but I recently completed respoking two BSA wheels, and they both turned out pretty good. If your rims are in good nick, and you use the correct set of new spokes, you can't really go wrong. Take photos of both wheels with a digital camera before you pull them to pieces. Also, run a straight edge across one side of each of the rims, and measure any offset there may be. You will need a good spoke spanner, and will need to make up some sort of stand. I made a pretty cheap one which did the job ok, if you want a pic.
There are some pretty good posting s on other bike forums on respoking.
Dave.,
