Online: John.R
FI Softail Tank and Fenders Tinware
  • paulsails01
    paulsails01
    Hi Guys,
    I am trying to locate web sites or HD salvage shops that will sell and ship 07 + FXST Tin ware to Australia, does anyone out there in our community have dealings with either Australian or American shops that will do this?
    I am seriously considering a "project" of strip and make over of my present 09 FXST. All information will be appreciated.
    Cheers, Paul.
  • Yob
    Yob
    I have bought a 2007 fxstc kit off a place in the states before & i will find an email address tonight when i get home.
    Get a picture of the fuel sender mount inside the tank as they will sell you a 2008 tank as 2007, requires 2008 sender unit & adding an earth wire to the outside of the tank at the fuel pump plug.
    2008 tank will fit without modifying the inside of the tank, as i found this out 2 years ago when i did the same.
    Yob
  • Yob
    Yob
    Should have read bottom line 2009fxst
    I think the tin ware was different on 2008 on, may pay to check with stealer.
    Try Peter Stevens Harley as they often have dealer take offs at cheaper prices than you can freight in.
    last kit i bought in cost me $767 including freight from the usa.
    Yob
  • paulsails01
    paulsails01
    All good info guys, thanks for the effort and time to help.
    Cheers, Paul
