Is it normal for a 1200 to be rattly after 10000km?
  • Midnite
    Midnite
    It sounds rattly at idle and you can hear it throttling on, more so since ive got a quiter pipe.... but is what i am exp... valve train noise and is this normal?
    midnite
  • houseofspeed
    houseofspeed
    Well midnight , i would check all the easy things first , 1  Oil level  . 2 Premium grade fuel . 3  All bolts and nuts for tightness . Has it been serviced by yourself or anyone . As you say you can hear the noise now that you have a quieter pipe on , i would try and road test  an equivelant bike from the Harley dealer ( Type , year . mileage ) if thats possible . Remembering the 1200 is an aircooled motor so it will make some engine noise . The foreman of any Harley shop will be able to tell you immediatly if your noise is out of the ordinary . Hope this helps ,  tell us how you got on .   Good luck.
  • houseofspeed
    houseofspeed
    Sorry , meant to write Midnite
  • Midnite
    Midnite
    Hi Houseofspeed, thanks mate........i hate noises, im a perfectionist when it comes to these things..., im running screaming eagle oil in it, which isnt the best i usualy run-  mobil1 vtwin - but im going to buy some amsoil as ive been told this can quiet it down a fair bit.... i get it serviced by the local shop, good rep, and i service myself in between the compulsary services.. in other words every 5000kms i change the oil, filter ect and go over the bolts ect.
    I recently changed to a two into one pipe which quieted it down a bit and noticed it straight away.. taking it on saturday to see what they say...
    midnite
  • Rocky2010
    Rocky2010
    Most Sporsters if not all Sportsters have a lot of Valve Train noise which is normal
    Did you notice the noise when you run the standard exhaust, thats if you had standard exhaust at the start.
  • Blackadder
    Blackadder
    Same here. Mines got 13k on the clock and sounds fine. A little clunky at times with the gear change, but nothing worrying
  • Midnite
    Midnite
    Hi Rocky2010, bought it brand new with s&s slip ons, so i never heard it st but i would have to say the two into one system is the quietest i have had on there.
    Got any friends with similar bikes? Get them to listen - I've watched guys go into paranoia overload when it comes to phantom sounds. I've also known guys who's paranoia was based in fact, so better to get these things checked out.
  • BAKES
    BAKES
    ipod, ear piece head phones, and plenty of volume.
    problem solved
  • bertiebettle
    bertiebettle
    My 1200 has a bit of top end rattle from new, more than my 883l with 32000k's in it, ask about it at first service and was told the newer engine are a little nosier and there is nothing wrong with it.
  • Midnite
    Midnite
    You dont think it might be a loose primary chain making this noise?
  • mintpaul
    mintpaul
    I'm the same as Scouser.
    I have been told to try a heavier weight oil like a Lucas 50w that is better for the Vtwin especially in the OZ climate
  • skirtster
    skirtster
    Mine rattles ,can't remember it not rattling still goes well after 60,000k's ,I use screming eagle oil & change it every 4,000k's.
  • Midnite
    Midnite
    Turned out to be loose primary chain... just adjusted it and no more rattles..
  • Midnite
    Midnite
    Hi Scouser, its the bolt and nut under the primary case..right next to the kick stand. There are few ways to adjust it and the method i used was to get it up to normal op temperature. Left it running and carefully adjusted it until it began to whine then backed it off. The other method is to disconnect the spark plug leads, open the primary chain viewer  place  a flathead screwdriver inside to test the slack, remove it crank the starter motor, you need to be testing about six times to get the most accurate reading. adjust it between 6.3 to 9.5 mm for hot engine, 9.5 -12.7mm for a cold engine..
    Hece why i adjusted it while running, the chain should not whine otherwise you will wear it out prematurely
    midnite
