brake pads
  • davidjohn
    davidjohn
    is it hard to replace brake pads front and rear  on a 2008 ultra and dose anyone have part numbers    grumpy
  • Harvey Mushman
    Harvey Mushman
    Never done it but can give ya part Numbers.......
    41854-08   Front  (Fits '08-Later Touring models)
    41852-08A Rear (Fits '08-Later Touring models)
    Page 824 of the latest Bible ........
  • davidjohn
    davidjohn
    thanks for the info safe rideing
  • AJ56
    AJ56
    Very easy to replace the pads. Remove the pins slide a wide thin wedge in between the pads and the disk, to give the new pads some space new pads in and replace the pins. Just be careful with the brake fluid as it will be forced back into the reservoir and could over flow. Get yourself a syringe and take some of the fluid out before starting and top up after the job is done.
