Online: softfat
What engine and clutch oil to use
  • bryjen
    bryjen
    I need to carry out a first service on Jenny's 2008 Sportster nightster and also do a routine service on my 2006 StreetBob.
    I will need to drain the oil in both bikes as don't want to mix oil from the UK with oil from here.
    Any ideas what engine oil and what clutch oil I should get?
    Thanks guys
    Bryan
  • issues2
    issues2
    I use Penrite Diesel oil in gearbox engine & primary.
    Harley recommend it if you can't get overpriced genuine HD oil.
  • smeemn
    smeemn
    Use a good quality oil with the correct weight in the engine, gear oil in the gear box and 20w 50w in the primary,,,, not car oil with friction modifiers.
  • groover
    groover
    I've noticed that mineral gearbox oils are of 80 - 90 viscisity
    Where as the synthetic gearbox oils are rated at roughly 10 - 40 viscosty.
    Any of you brother spanner-heads had experience with these two types of oils, even in the mining industry.
  • Chromy
    Chromy
    Mobil 1 V-Twin 20W50 in both holes.
  • smeemn
    smeemn
    Dont put gear oil in the primary as the clutch wont work correctly.
  • dlx1
    dlx1
    7 years ago
    hi everyone
    can someone tell me what engine oil i should use for my 2015 deluxe 103
    im not sure what to use out of 3 of my choices mobil1 twin/penrite 20w-50/or genuine harley hd3
    I'm going to start servicing my bike myself
    oh also what to use for gearbox and primary
  • srd0060
    srd0060
    7 years ago
    Try this it’s good.is anyone running thicker oil for summer or just stock Harley oil?
  • dlx1
    dlx1
    7 years ago
    ok thanks what about for tranny and primary
  • Ferrett62
    Ferrett62
    7 years ago
    The dealer tells me the harley oil sold in Australia is made buy penrite, if thats the case they sell it for the same price as penrite.
  • Big Steve
    Big Steve
    7 years ago
    Motul Twin Syn in the motor, Changed every 5000km
    Spectro Transmission in the tranny changed every 10,000km
    Spectro Primary in the primary changed every 10,000km
  • Steve L
    Steve L
    7 years ago
    I was talking with a bloke today who I was doing some work for and he highly recommends diesel oil for the engine and specific gearbox oil. He used to work for a company that tested oils. He really likes RX super and uses it in all his vehicles, even the wife's new Toyota hybrid.
  • robots
    robots
    7 years ago
    Those penrite are way too thin, okay for winter for a few months
    Castrol GTX 20-50 or the Valvoline 20-50 mineral been using 8000km change,  same in primary and nulon mineral in transmission
  • Hound_Dog
    Hound_Dog
    7 years ago
    I use, Liqui-Moly 10-60W in engines, ATF in primary and Redline Shockproof in gearbox.
  • Wholehog
    Wholehog
    7 years ago
    Mobil v twin for the crankcase.
    Redline heavy shockproof in the gearbox.
    Redline high temp ATF in the primary.
    Just what I like to use in my 103 fat bob
