changing pipes?
  • mattyb
    mattyb
    hey all,
    new to harley's and have a 2005 fuel injected softail deluxe and wanted to change the standard pipes with mufflers that are on it to a set of vance and hines shortshots,
    and just want to know if i need to get the bike tuned after i fit them or weather it will be alright just to swap them over,
    thanks
    matt.
  • andij
    andij
    all noise and little performance, their slip ons with stock header pipes works better than most set of pipes
  • mattyb
    mattyb
    yeah i spoke to someone at peter stevens today and was told that if im only doing pipes dont need to get it tuned, but when i fit a heavy breather aswell will need a tune cause it will be running to lean,
    is this true?
    Fit a Tuner
  • mattyb
    mattyb
    Yeah I'm looking into a Vance and Hines fuelpak atm
