Online: obisteve
cams for 96 cub carby engine
  • wiseylovesholdens
    wiseylovesholdens
     Hi , I am about to up grade my 88 b cub engine to a 96 cub , the engine is carby feed .
    My question is what cams to put in as the bike do,s mostly touring work & i would like to keep my fuel economy.
  • andij
    andij
    what bike dyna ,softy ,touring
  • wiseylovesholdens
    wiseylovesholdens
    Sorry , yes 2005  softail standard , has mikoni carby & filter upgrade , 2 into 1 pro pipe exhuast
    Running 67 tooth rear cog which took 9% off the engine RPM at 100km/h
    Runs sweet , just looking for a little more torque when two up
  • 2005 FLSTFI
    2005 FLSTFI
    Do you mean change out barrels & pistons to 95". Going to 96" you would have to change crank for that year
  • Aunty X
    Aunty X
    Might pay to look at the Andrews website. Perhaps the 26G gear driven cam would suit.if you were going to 95. If you were going to 96, I'm sure you will need something bigger.
  • wiseylovesholdens
    wiseylovesholdens
    I have purchased a set of barrels & pistons from a 96 cub engine to put on the 88B engine but question is what cams to put with them
    hi, that piston is the same dia as what is in your motor you will have to buy  a  new set set of big bore 3 7/8 " dia for the 88c.i.,
    88c.i. is the same size piston as the 96 c.i. stock,   cheers
  • wiseylovesholdens
    wiseylovesholdens
    thanks guys looks like it may not be as easy as i thought
    But all is not lost I think we will just bore the new barrels to suit , may as well flow port the heads while where there .
    thought we might be able to get out of this one easy , (not the case) so it will be engine out and do it properly just another job for the winter
    Any recommendations for an Engine builder more than willing to send it the right people.
  • Chromy
    Chromy
    Cyclerama 575 cams.
    Excellent for touring work.
    http://www.cycle-rama.com/CRProducts.html
  • wiseylovesholdens
    wiseylovesholdens
    thanks people but I,ve decided to just rebuild the 88 and be done with it
  • Aunty X
    Aunty X
    Then the Andrews 26g cam will be an ideal cam for you. There are other equivalent brands eg Woods. Worth getting if you've got some spare cash.
  • andij
    andij
    ive had 585 s@s cams in my old 88 but had heads to match ,read up all info and put your choices on forum to get feedback .
