Online: beaglebasher, HD17
retrograding efi back to carby
  • mattyo
    mattyo
    im planning a ridged chop on my sporty. Can anyone out there give me a step by step on how to remove an efi system off my 08 883 and replace with a carby. What parts would i need, ive heard i may need to change the cam shaft and other bits.
  • mattyo
    mattyo
    well ive got a couple of friendly grey beards at work who ride harleys. ill keep on it cause im turning my girl into a ridged bobber wwith a springger n im shit a electrics so it makes sense to me to remove everything electrical that is possible
  • skirtster
    skirtster
    I don't think you need to change cams,you would need the ignition from a carbied evo,don't need o2 sensers, fuel pump,1/2 the wiring loom or ecu ect.It would proberly lose performance & not run as smoothly.Personally i would build it with the injection for realiability,economy & performance.I have seen hot rods run gutted carbies as throttle bodies & nobody notices there injected, looks old school
  • mattyo
    mattyo
    Making a jig n making it ridged myself
  • mattyo
    mattyo
    Yea im a boilermaker
  • Hound_Dog
    Hound_Dog
    Mattyo, you will do it with ease then mate
  • mattyo
    mattyo
    yea me thinks it should be pretty straight forward just need to chase up an engineer up this way to get a compliance plate. found a nice premade weld on hardtail from bitterend choppers that should be pretty easy to fit
  • Hound_Dog
    Hound_Dog
    Mattyo, check also the V Twin guys in NY they do great weld on hardtails. I got a great one for my Shovel from then thru Zoom Cycles
  • mattyo
    mattyo
    Yea I did and the bitterend one one is sourced from vtwin. Bitterend does them in a kit form including the tail with other bits n bobs needed for the job
  • 666
    666
     hey matt did you end up doing the retro efi change over was it a delphi induction module??
  • mattyo
    mattyo
    na car blew up so had to put a hold on projects for a while
