Online: Retroman, Hilly
FXDL Low Rider Front & Rear Axle Nuts Sizes
  • travelling2008
    travelling2008
    Hi all , I am in little bit of strife as some stinking low life  has ripped of most of my tools from my garage (Bastards)
    I need to remove my front wheel & back wheel for tyre changes and could use some advice on what size nuts these are, so i can go and purchase the spanners to do this.
    My bike is a 2008 FXDL Low Rider, I am so unsure wether the nuts are metric or Af, any assistance would greatly be apreciated.
    May the force be with you.
  • travelling2008
    travelling2008
    Hey many thanks for that,as i really need to get my wheels off and dont want to buy the wrong spanners.
    I will go down and purchase some AF tools and hopefully be able to remove the wheels.
    Again thanks for your help.
  • smeemn
    smeemn
    I think the front will be metric,the rear imperial. Buy a shifter that will do both.
  • Stumpy
    Stumpy
    If you use/buy a shifter get a 15 inch/450mm one as I undid my rear axle nut and a 12inch/300mm is to small. You can use a 300mm shifter on the right side but have to use the larger one on the nut side. Hope this helps mate.
