07 Dyna front disc fault ?????
  • Zarbs
    Zarbs
    Hope someone can enlighten me.  I recently fitted a jaybrake 6 piston brake caliper to my 07 Dyna street bob, front disc is the factory 11.5 inch full floating design type.  Brake works great but recently started to hear a clunk in the front end when I applied them.  After some investigation I found the outer section of the disc was moving on the floating rings that attach it to the inner section bolted to the hub.  Has this happened to anyone else?  Do I have to fit a solid type disc so this doesn't happen again? Any help appreciated.
  • smeemn
    smeemn
    It's called a floating disc,which moves around hence the name.Nothing to worry about.
  • Zarbs
    Zarbs
    Thanks for the input blokes.
    I agree it is a major safety issue and took the appropriate action of replacing the disc with a new solid unit.
    All good now stops great without the clunk. Maybe something to keep in mind if doing a caliper / pad upgrade.
    Anyway cheers,
    Zarbs
