Drain Plug Leak
  • PKN50
    PKN50
    Softail with under 1000klms developed an oil leak from 1 of the crank oil drains on my first long ride, turned back after 160klms and returned to dealer on Saturday arvo, problem has been fixed I hope but anybody else had this problem ?
  • smeemn
    smeemn
    Thanks for that will keep a look out
  • BURTO
    BURTO
     Whats a "crank oil drain"? and how many is there?
    Burto.
  • AJ56
    AJ56
    maybe he means the crank case oil plug that is not supposed to be removed.. Easy fix really just use some lock tight on it. That's the only one I know of
  • Harvey Mushman
    Harvey Mushman
    Carefull with that.It's a tapered thread.Too tight and you will crack the case.
