113ci upgrade
  • Springer_13
    Springer_13
    So the times come to pull the 80cube out of the EVO.
    I've wanted an upgrade for sometime now.
    I am going 113ci, now the question is what brand.......
    Revtech- All I read are bad reviews
    Ultima El Bruto- I haven't heard anything too bad, what I have heard is from people abusing them
    S&S- same as Ultima, only heard of failures over motor's getting a working over continually
    Has anyone had/heard any experience with either of these three?
    Springer
  • issues2
    issues2
    Found a forum years ago from blokes in the U.S that were all Custom Builders.
    All said they wouldn't touch Revtech but if the customer wanted it so be it,no warranty from them the builder
    Ultima,only if you couldn't afford S&S
    S&S,top of the line.
    Having said that though they all agreed that no matter what engine was purchased new,it should be pulled down & checked anyway.
  • Springer_13
    Springer_13
    Yep after talking with BRANKO and another mate I'm sticking with my initial decision of S&S.
  • Hound_Dog
    Hound_Dog
    Dan, old mate, Im suprised you are not thinking 145 Tribute motor!!!
    Springer 13, if you can get a Treese 113" twin cam ( nothing to do with HD twin cam & bolts straight in to EVO frame ) you got a good motor!
  • Springer_13
    Springer_13
    have laid the hard earned down and ordered through BRANKO am also
    takin the chance to throw in a 6 speed to replace the 5 speed.
    The S&S Evo 113" is good, but i still say the Treese Australian Designed & built JUst use S&S FLYWHEELS & heads is the best stronger cases better crank case breathing and the best power & torque curve of the lot as John Treese designed the cams had them made here in Australia. think you buy them in QLD.
