Online: Stuart, Hilly
StreetBob Hangers
  • troopa
    troopa
    Hey All,
    Has Anyone fitted a set of low or medium Bonanza Fat bars (by Fred Kolin) to their streetbob? Wanting to know how tall i can go with stock cables etc. I was initially wanting a set of 12 or 13's but apparently these bars only come in 11"(low) or 14"(medium). Any info appreciated, even different branded fit-ups as i could go off the measurements and roughly work it out. The bonanza's in both sizes have 7" centers, 6" pullback, and are both 32" wide. Oh, and my S/B is an 07'.
    Cheers, Leigh.
  • Daggs
    Daggs
    wiring will be no problems but if Yr looking at 14 or 15 high brake, clutch and throttle cables will need to be longer ones
  • Daggs
    Daggs
    200 is awesome, the Avon is way sticky and feels so much better through the twisties,
    its softer of course so doesn't last like the standard dunlop but that doesn't worry me one bit.
    the way it fills the guard is the way it should look from factory.
    Just put a 110 Metzeler on the front so can't wait to see how it goes, just waiting for my fork lowers to come back from the powder coaters, epoxy paint baked on didn't handle the stone chips...
  • Daggs
    Daggs
    arrgghh !!! don't tell me that ...
    just have to see how it goes I guess, the Black on the Factory FatBobs seem to survive ok, I thought they would be powdered....
    I did mine after seeing the Fat Bob...... had mine coated through Adelaide Bike Works so not sure who did the actual powder coating.... Let me know how yours goes.... guess I'll also be seeing you at Edenhope
  • Daggs
    Daggs
    Yeah I'll be there this year, had to miss last year coz of work, will be good to catch up
