1340 shovel compression
  • clarkie
    clarkie
    what compression should i have on low comp model 1340 shovelhead.
  • angry
    angry
    hard to get exact details, but i believe  no lower than 100psi up to about 130 psi. as close to even is ideal
  • houli
    houli
    Depends on what pistons, cam, how old the engine is, lot of variables, what have you got?, within 10% of each other, tspoon of oil in plug hole and test if it jumps up re ring it, if not valve job.
  • DaveP
    DaveP
    Can I ask why you are asking this question? do you have an issue or symptons? or just wondering.
  • clarkie
    clarkie
    asking because not sure about it,did a test and found 88psi in both cylinders,but bike seems to be running ok,may be i stuffed up test,will do again,still leaning about these bikes,thanks for asking
  • DaveP
    DaveP
    88 is low. make sure the throttle is wide open and wind the motor over at least 4 or 5 times to get a reading.
  • clarkie
    clarkie
    ok i stuffed up just tried again with better gauge and got 115psi in both cylinders,did it a couple of times and was the same each time,bit happier now,thanks for help davep.
  • DaveP
    DaveP
    All good mate
