squeak noise???
  • motor_head
    motor_head
    Have you checked front wheel bearing and brake pads ..... i had a similar mystery which turned out to be a bolt on my front brake caliper had vibrated out and the caliper was not sitting in the right position.
  • FatRob
    FatRob
     It's your new leather pants sliding on the seat when you roll off the gas.
  • smeemn
    smeemn
    I think it would be your belt,they make a chirping noise sometimes.Its a sign that your belt is either dirty,worn,misaligned or not the correct tension.Start by cleaning it then a bit of silicon lube,check the tracking and tension.Last if it still shits you replace it.,Hope its an easy fix.
  • Aunty X
    Aunty X
    No idea. May be worth putting up on the post where you think the squeak may be coming from.
    I do have a story to tell though whiuch may make you laugh/make you think I'm a dickhead/etc/etc. I heard a rattle noise that pissed me off while riding. It would only happen at speeds above 50 kays or so. Checked everything out on the bike, nothing was loose. I'm thinking " fcuk me ... what's goin on" . On the next ride ( to work ) I heard it again, and then I realised what it was. The rattle I was hearing was actually the top button of my jacket flapping in the wind and hitting my helmet. OK SEQ crew, let the piss taking begin.
  • rider
    rider
    Flood water and dirt roads ? definitely check for dry wheel bearings.
  • DaveP
    DaveP
    I agree with smeenm, sounds like the belt. Go and raid the misses cleaning cupboard for the Mr Sheen. Its silicone and works a treat not just on your paint and chrome, but on the belt as well.
  • angry
    angry
    some Evo engines whistle through the breathers when you back off,specially if the have a few kays on em. sounds like a cross between a whine and a whistle,but only when you back of,more prevelant when its cold or wet or both. something to do with the breather set up in the heads. fairly common.
  • smeemn
    smeemn
    Sounds like the belt,when you throttle off the belt flexes,tension goes from top of the belt to the bottom and makes the sound,Try and tighten the belt a little.
    Ear plugs thats the solution....lol
  • Hound_Dog
    Hound_Dog
    Hey mate, I have a 97 Fatty that makes what I suspect is the same noise. Its belt chirp mate most likely. Check your tension....you should be able to only twist the belt 45 degrees is a rough bush mechanic guide. Give it a clean and use the Mr Sheen or you can get proper drive belt lube. I personally dont worry about it mate.
  • SJ
    SJ
    Also if it belt chirp.... you said you didnt hear it on the country roads.... could that just be because you were on open roads - there were no median strips and concrete dividers everywhere to bounce the noise back into your ears?
    I reckon if it is belt chirp you woudnt hear it near as much on open roads (especially that low down on a bike). My sporty does whine a little when backing off the throttle, but it seems to come from the air box as someone else mentioned.
  • cactus60
    cactus60
    cricket in the handlebar.
  • robert65
    robert65
    check out ya gear linkage from frt to gearbox .see if its loose at all . while you are riding put your heel against the rear shifter and see if that helps get rid of the sound . It happened to me on my roadking very annoying.
  • WWW.AJ
    WWW.AJ
    maybe a cracked rear header exhaust braket
  • smeemn
    smeemn
    Try heating the compensator with a heat gun,and undo while hot.
  • Harvey Mushman
    Harvey Mushman
    Jesus.If you've broken a Sidchrome breaker bar,you've tried heat,and you can't use a rattle-gun,how the fark do the mechanics at the stealers get these suckers off ?
  • smeemn
    smeemn
    You are undoing it, not tightening it ????????????? right hand thread ???????
  • lucky
    lucky
    may be not the belt but the pully out of wack , or possibly worn , ???????
  • smeemn
    smeemn
    sent the finger prints to a fortune teller she said
  • smeemn
    smeemn
    Well ok,,,,, She said thats part of a spring from a gear box,The gears will be ok so put it back together,you don't do dishes or work on your bike,have a good fingernail specialist and a good camera.lol
  • smeemn
    smeemn
    ??????????/ which is right ???????/ shit the tables have turned !!!!!!!!!!!!!!!!!
