2 up on a 883 ?
  • BACAMICK
    BACAMICK
    hi guys , any of u ride 2 up on a 883 ? wanting to no how they go, i ride the missus 07 883 with pipes powercomander and it seems to go like a big bike should, i have no probs sitting on 160k on it ,  im selling my bob and dont want to spend $ on the 883 , pegs dual seat,  the plan is to travel in the next couple of yrs and need to have a bike that dont matter , our combined weight is 160kgs
  • jim76
    jim76
    Gday i have a 08 883c the only let down i have found is the shocks i have replaced the rear with icon and they seem good but i will have to have a play with the settings on them the front shocks are stock and need fixing soon. As for power i have a thunder max,SE 2 pipes and the air filter replaced bike runs well with the two of us on bike its about 170kg i would be happy to go on a long run as it is hope this helps
  • 883n Harley Convert
    883n Harley Convert
    My wife and I ride my Iron all the time, we're weighing in at around 140kgs and have no issues now. I had a similar experience to Jim76, original shocks were rubbish and continually bottomed out so I bought a set of the HD Heavy Duty two up springs and haven't had an issue since.
  • kevlad
    kevlad
      without changing the shocks it will be like  riding a fat chick it will woble all over the place
    i went for 12 inch  progressive  2 up weight 185kgs  on a 1200   does it easy   but my arse is  close to the road  so seat issue is not a problem
    its loud its harley dont frig with nature
  • labate
    labate
    We used to ride together(160 kgs) all the time... there's a lack of room, but is ok...
  • Rocky2010
    Rocky2010
    Plenty of power for 2up, standard Harley shocks need to be replaced if you are going to be riding 2up or they will bottom out even on the hardest setting.
    Seat you will need to get a large seat like the sundowner to be comfortable as the standard seat is no good.
    All up the 883 will do the 2up riding, but to be honest I have done it on my partners bike and with me riding it is very cramped making you feel like your sitting on the tank the whole trip. The bigger bikes in the Harley range are more suited to constant 2up riding.
  • BACAMICK
    BACAMICK
    thanks for the replys all , gives me a little more to think on
  • terroristone
    terroristone
    maybe weight is the issue, let us know how much you both weigh, im 60kg and my miss's is 41, so i think we'll be fine for 2up.
    Andrew
  • r0880
    r0880
     I've had to double a mate after he broke his bike, and my 08 883c had a noticeable power drop.  It wasn't as if you couldn't maintain 100 on hwy but you might need to drop a cog on a steep hill.
