Online: obisteve
What's a good fix
  • beagle
    beagle
    I have a 2011, 103 SG.  It runs like a freight train, but is still too lean with the "parade mode " coming on only after a couple of minutes idle and also a hint of backfire on decel.  It's fitted with SE pipes but the rest is stock.  Are there any plug and play fixes to richen it up a bit.  I have no interest in doing anything else to the motor as far as go fast modifications go.  regards,  beagle.
  • smeemn
    smeemn
    Turning parade mode off wont fix the heat,It needs a tune then it will go even faster.the parade mode helps stop the motor from getting too hot and blowing head gaskets.
  • beagle
    beagle
    Ended up sticking a PC V with a stock map into it as a quick fix. Seems to have smoothed it out a bit and better idle. Will change to a KnN hi flow filter and remap when it needs replacing.
