Online: John.R
97 bigbore and woods cams info maps
  • BURTO
    BURTO
     Don't think M&M sell Woods Cams........got mine from www.fuelmotousa.com.......good price and quick delivery (6 days!)
    Andrews 54h is another popular cam.......a bit cheaper than the Woods too!
    The cams you decide on will determine a lot of where to go for the rest of the build. eg- Compression, heads, etc.
    It all has to work together.
    Burto.
  • AJ56
    AJ56
    I run Andrews 21 in my 96. Good low down power. Nothing else has been done to the motor at this stage. You could use and of the bolt in cams for you 88. The 26 are popular.
  • andij
    andij
    ask FYO he did this set on his88 try him on wa section ,or on single dad porn section
  • CraigAdel
    CraigAdel
    Hi
    Have a 09 Road King - had SE 204 cams , quick install Pushrods, Monster Ovals, HD EFI Super Tuner and Mach 5 air cleaner  and catalytic converter removed  yesterday - dynoed today at HHeaven.  Max Power 86hp Torque 97  - how do those figures sound? Just curious to compare to other bikes.
