Stop LIGHT
  • PigironBob
    PigironBob
    The stop light on my '08 FXDF remains on all the time, is there some way to adjust it so that it only comes on when the brakes are used?
  • PigironBob
    PigironBob
    Yep that's what it was, apparently I didn't relocate switch box / throttle hand grip correctly after changing the grips last week. As you say easy fix. Thanks
