Online: John.R, baldy1450, softfat
Flush Caps?
  • Rocky2010
    Rocky2010
    You don't have to remove the tank to install bling caps, under the front of the tank on the left side there is a black plastic flap. You open that and pull out the connection plug, remove the pins inside the connector then pull the wiring up through the pipe in the tank to remove the original fuel cap. Then install the new cap in reverse.
    Shouldn't take more than a half hour, hardest part is removing the pins from the connector if you don't know how they come out.
    Simply put a long needle inside the back of the connector raise the plastic clip then pull out the pin, just remember the colours and where they go.
  • smeemn
    smeemn
    Those flush mounts look great. not cheap though ?
  • jungle
    jungle
    how much ?
  • Frnkstn
    Frnkstn
    Bout the same price as 8 kilos of bananas.
  • FXSTC 09
    FXSTC 09
     I actually priced one yesterday and a flush mount fuel cap and matching LED gauge retail for $305 at Peter Stevens in Adelaide
  • jungle
    jungle
    where,s m&m
  • FXSTC 09
    FXSTC 09
    As above, how do we find m&m?
