Online: John.R
1200 sporty advice
  • albi
    albi
    Hi everyone, thanks for a great forum.
    I've ridden bikes for 17 years, and have gotten to the point in my life where I'd like to buy a Harley.  Budget only allows for a sporty at this stage.
    I've found a 1996 1200 sporty with 29,000km and a service record for $10,000.  It's very clean and unmodified except for mufflers that look like screamin' eagle copies, and an original sissy bar.
    I've looked around a bit, and I really like this one.  Does it sound like a good deal?  Any nasty things I should know about that model?
    Thanks - here's a pic of it.
  • toxic
    toxic
    ^^^^^^^^^^^^^^^^^^^^^^^^^ WOW THAT'S DIFFERENT ^^^^^^^^^^^^^^^^^^^^^^^^^^
    Wonder how I managed to get my post to do that
  • dav66h
    dav66h
    i would have thought you might be able to find something a bit newer for that sort of money it seems to be a buyers market on used bikes ,but if a genuine good thing?
  • albi
    albi
    Thanks for all of your comments and advice.  I really appreciate them.
    There are a few cheaper sportys, however, they're generally not as original or have more KM's.
    I'm going to have a closer look, and will let you know how it all goes.
  • LOFTYBOB
    LOFTYBOB
    Why not go for a much cheaper, but later model 883 Sportster and put a 1200 Kit in it. Will work out a lot cheaper and you'll have a much later model. I reckon KC did his conversion for under $2K.
    Good luck.
  • kingchops
    kingchops
    Yep, good advice Bob, 2k for fuel injected models ('07 up) but if you buy an '04 to '06 883 you can do the 1200 conversion for around $1,200.
    Since cash is an issue just buy an 883 (I've seen a few 04 plus customs go on Ebay go for $11k and under) then wait for the 1200 conversion till later - lower Ks and rubber mounted engine etc etc. My 07 custom cost 11K.
  • grafpak
    grafpak
    if its at a shop -take it for a ride!!if you like it go for it..............................
