Suggestions
  • DarrenO'Donnell
    DarrenO'Donnell
    Hey guys thanks to all who chimed in on the O2 sensor installation on my 06 night train.
    Just wondering if anyone has any ideas on the closest map for my build now I have them installed. It's got a revolution 98"  (1605cc) kit in it, andrews 54 cams,screamin eagle heads,V&H big radius 2 into 2's and a hypercharger. The cal file listing says a level 176 cal must be used now I have the O2 sensors  but I tried DPS176-03 but it wouldnt let me change the injector flow rate or displacement??
    Am I missing something?
    Any suggestions????
  • BURTO
    BURTO
     Darren, I think you musta missed something!
    Go into ECM tuning constants, then click on the Engine Displacement Setting (default is 103.1), now go up to the tool bar and click on "2 units", then Decrement it down to 98 or whatever you want.
    Similar process for injector size.
    Burto.
  • DarrenO'Donnell
    DarrenO'Donnell
    Thanks Burto I will have another look as soon as I get a chance.
    And cheers Hilly I checked out the DPI but the cams are not as close to mine.
