Fellas,
I've nearly finished the 103 stage 2 kit install into a StreetBob (includes SE255 cams). All has gone well so far, however, when I fastened the rocker arms down, I couldnt get the free play in the pushrod as required. The manual says that with the cam on base circle, that I should be able to "lift up lower push rod covers and verify that both pushrods spin freely". I noticed that as I fastened the rocker arms down, the exhaast valve seemed to tension up a bit.
I'm currently using the stock pushrods and assumeed that they should be the correct length. Can anyone see what I'm missing or should I bite the bullet and throw adjustable pushrods in??
Carlos
