That is i currently have a enclosed primary/chain......but like the idea of an exposed belt.....not i could go out and spend $3G's for a kit, but beleive i can do it cheaper....but cant get my head around what bits ill need. 85 FXWG. -4 speed
Front Pully - + shims, nut
Rear pully/clutch basket - i want to retain starter motor so needs ring gear? (happy to kick it for a while until i can find a primary case to cut back.
Also want to swap to chain drive/as pulleys and belt need replacing anyway, ill try it and if i dont like it ill swap back.
Belt/ wanna run it exposed
do i need to change out my clutch?/needs attention anyway...but what do i want
Thanks
