Online: Stuart
Daytona Twin Tec TCFI3 Tuning
  • assclown
    assclown
    G'day all, Just hoping somone can give me some advice here.
    I have the Daytona Twin Tec TCFI3 and wego 3D Controller.
    My question is about the BLM table cells.
    I have two cells at 10%TPS, 1500 and 1750 RPM that always register as 75. This only occurs in the front cylinder. I have applied Front BLM and reset both BLM tables approximately 6 Times so far.
    Each time I download information from tcfi unit the same result comes up. I have also tried setting these problem cells at 120 but still same result.
    Can anyone tell me if I was to apply blm and reset blm, Can I place a number 1 in these cells to stop the Block Learning Process for these cells only? And if so, does this mean that these two problem cells will stay locked in at 100, as per the reset, or will they stay at 75?
    The reason I'm looking to fix this as it has created a slight knock on throttle roll on. This does not appear after the initial reset until about 10 minutes into the ride. So I know the reset is working.
    I hope this is clear enough for you to understand.
