Online: Rextheute2022, Merv
21 inch in lieu of 19 inch
  • Deadwood
    Deadwood
    Chasing a 21 inch front (laced) rim and am wondering if I find one to suit my twin disc front end will it bolt stright on under the front guard? Anything else I need to buy, bearings etc?
  • black29d
    black29d
    Hi Deadwood
    I have converted ny 07 superglide with custom made wide trees and a 21 inch wheel.
    The standard 21 inch wheel is  to wide for stock trees, if you lace a rim to a dyna hub, it should fit.
    As for the front gaurd, clearance isn't a problem,  it fits under
    this is the thread to my conversion
    www.hdforums.com.au/Default.aspx
  • Deadwood
    Deadwood
    Thanks for the heads up. I've actually done a wide glide conversion a couple of months ago from Vulcan Engineering.
    Would that make life easier instead of lacing a hub?
  • Deadwood
    Deadwood
    Soon buddy. Got some white walls going on today so it will be later in the year before I look at another one.
