Online: Rextheute2022, Merv
2008 Street Bob Pipes air cleaner tuner?
  • Kmankman
    Kmankman
    This is my second Harley but ive never made any mods to any of them. Got a new one now, 2008 street bob all stock and I want to add pipes and air cleaner. My question is should i get something like Dyna Power commander or just have dealership map ECM? Also, what kind of power should I expect from a change like this. And of course, what pipes and air cleaner do you all recommend?
  • Simo84
    Simo84
    And cue 9 different opinions ine three... two... one...
  • Hesh
    Hesh
     Agreed. It's something I want to eventually do but don't really wanna screw with my last remaining year of warranty.
    Have trawled through the "Workshop" thread at all the different EFI opinions and am still completely confused/undecided.
    Thundermax........TTS.......which to choose!!???
    Good luck Kmankman, ya gunna need it
  • Jonesywa
    Jonesywa
    2008 Street bob
    V& H short shots
    Hyper charger
    HD remap
    Bit of De cel popping but Goes great
    You have to way up what your looking for, It's it All flat out performance? Just for Looks? or just to know your got a liitle extra power when you need it? If it flat out Performance you need the TTS with a Good Exhaust something Mid Lenght and Steped Header , Mo-Flow or Spike and SE Heavy Breather. Will give you lots of Flow and Power
  • kingchops
    kingchops
    I've got a 2008 SB with V&H big radius 2 into 2, Arlen Ness Big sucker and TTS tuner.  I took an 09 Bob for a test ride before buying mine and the performance over stock with those mods is quite a bit.
  • Thomo_Baca
    Thomo_Baca
    mines got thundermax, arlen ness big sucker, S&S slip ons
  • smeemn
    smeemn
    Allthough I don't have TTS I would recommend it. Sounds like the best system out there.But if your worried about warranty, then only the factory flash over will keep it.
