Online: baldy1450
Off/Run Kill Switch
  • Harvey Mushman
    Harvey Mushman
    Hi All,Harvey Mushman here,back with his next installment of noob question time.........
    With all of the bikes I have owned in the past,I rarely use the Off/Run kill switch (except in whatever emergency).I have only ever used the key switch to stop and start the engine.With the ignition off,it made no difference what position the kill switch was in.
    My question is - with my HD even with the main tank switch off,and my key fob out of range,what is it that I can hear energise ?  when I switch the kill switch to the "Run" position,then hear it de-energise ? when I switch it back ? I thought with the fob out of range,everything was disabled.Am I going to burn out any relays or reduce standing battery power if I leave the switch in the "Run" position ? My apologies for the questions,but if ya don't ask......
  • Kiwibouncer
    Kiwibouncer
    I very rearly use my kill switch always just use the ignition switch and it has never done any harm to either of my bikes. If you have a newer bike that noise you are hearing is likely to be the computer diagnostic thing it makes a buzzing type noise for a few seconds when you first turn the ignition on..........................but then i know bugger all about bikes just love to ride lol
    KB
  • jacks
    jacks
    When I first got my girl I used the kill switch to turn on/off and after 3 flat batteries (forgot to turn off at tank) now leave the bloody thing on and use the tank switch only...barstard of a thing....2 hours wait for Harley assist once.; now carry jumper leads!
  • HWG
    HWG
    I was told when i brought my first ever new Harley from a dealer not to use the kill switch as i costs a fortune to replace
  • rab2341
    rab2341
    Harvey Mushman is ........................................................................Steve Macqueen.
  • 48fan
    48fan
    I keep using the kill switch but it must be broken as it hasnt killed any of the fuckers pulling out on me yet :P
  • Humbug
    Humbug
    Never use the thing.....but my mate did once NOT FUCKING FUNNY I can tell you...... go to start the bike in the morning and no go,put it on the back of the ute and just befiore I drove through the shop gate a picture of my mate and I drinking in the shed and him shutting the bike down by using the kill switch popped into my head. Felt like a real fool I can tell you.
    He always uses the kill switch and I never do.
  • LordViykor
    LordViykor
    When I got mine the dealer said always use the tank switch as it helps reset the computer.
